internet-john's avatar
Mar 09, 2022
AX6000 (RBR850/RBS850) - Wifi constantly dropping from all devices
I have a consistent problem where wifi devices lose their wifi connection to my Orbi system multiple times per hour for 1-2 minutes at a time.  This affects all kinds of devices (phones, laptops, Oculus, TVs), and it happens even if I'm sitting within 5 feet of a satellite with nothing in between.  It's only a wifi problem.  When I use a hardwired connection into any satellite, it's 100% reliable without any issues.
I've read that having the 2.4Ghz and 5Ghz bands on the same SSID can cause this.  On at least a few occasions where I've run into this issue, I've noticed that my device was switching between the bands.  Is there a way to separate the SSIDs per frequency band?  I couldn't find an option to do so.
My setup consists of a router plus 6 satellites (3 of which are hardwired) in a 9,500 sq ft home.  The issue also happened when I only had four satallites (I added more thinking it would help).  I'm running firmware version V4.6.7.13_2.1.9.  The same issues happened on previous firmware versions as well.  I have about 25 devices connected.
    I've read that having the 2.4Ghz and 5Ghz bands on the same SSID can cause this.  <Where did you get your information from? This wouldnt' be a cause. On at least a few occasions where I've run into this issue, I've noticed that my device was switching between the bands.  Is there a way to separate the SSIDs per frequency band?  I couldn't find an option to do so. <Not supported on Orbi Systems.
    My setup consists of a router plus 6 satellites (3 of which are hardwired) in a 9,500 sq ft home.  How are the RBS ethernet connected to the RBR? Directly or is there a patch panel or LAN switch in between? The issue also happened when I only had four satallites (I added more thinking it would help).  I'm running firmware version V4.6.7.13_2.1.9.  The same issues happened on previous firmware versions as well.  You maybe over saturating your home with having too many RBS online as well. One RBR and I believe 3-4 RBS will cover a 10k sq ft home. I have about 25 devices connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
  • FURRYe38's avatar
    • internet-john's avatar
      internet-john
      Guide
      Thanks for the responses!
      They were all connected wirelessly.  I recently hardwired three of them through a new Netgear switch.  I have the same issue before and after hardwiring a few of them.
      I can try disabling some of them!
      ARRIS BGW210-700 (AT&T)
      Some are closer than 30ft.  I'll try spacing them out more.
      I'm using Auto and 48 on 5Ghz
      There are some, but the signals are very weak.  We're pretty far from our neighbors homes.
      No.  The issue has continued to happen for the last three firmware updates.
      Thanks, I didn't realize that
      • FURRYe38's avatar
        For the Ethernet connected RBS, How are the RBS ethernet connected to the RBR? Directly or is there a patch panel or LAN switch in between?
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        Try option #2 first.
        I recommend doing a full on factory reset and setup from scratch. Bring all your RBS near or to the same room and synce them one at a time wireleslly to the router. Then place back in there remote locations.
