kyngor
May 01, 2020Aspirant
AX6000 VLAN tagging
AX6000 VLAN tagging Can the AX6000 ($700) please get VLAN - SSID tagging? There are a lot of (a little more) technical users who want to have more advanced firewall, qos, web filtering, seperation,...
May 01, 2020Guru - Experienced User
I don't believe Orbi systems support VLAN tagging on the wifi. I would review the user manual to see if anything is listed there. IF no, then it's not supported. Something to check over in the Orbi Pro forum to see if the Pro version of Orbi AC does.
- kyngorMay 01, 2020Aspirant
Thanks for the reply.
That's what I figured.
It was an attempt to hopefully get someone from Netgear to hear he request :)
- FURRYe38May 02, 2020Guru - Experienced User
Reqeuests can be made here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Good Luck.
