DudeDah
Mar 09, 2023Aspirant
AX6000 Wired backhaul question...NEWB
So I am going to use a wired backhaul configuration for my RBS, is it "better" or does it matter whether I use the "Link aggregation" port on the back of the RBR vs. one of the other three?
- How Ethernet port 1 behaves is determined by a setting on the Advanced Tab, Setup Meu, Internet Setup. - Enabling Link Aggregation means port 1 is connected to the modem.
- Not enabling Link Aggregation means port 1 is just like ports 2-4 (connected to devices on the LAN).
 - See the user manual for the specific model of Orbi router (found on the product label on the bottom of the router).
- FURRYe38Guru - Experienced UserLAG is the for WAN side. WIred will always be better than wireless.
