philoouu's avatar
philoouu
Luminary
Aug 20, 2020
AX6000/RBK852 Missing Telnet access
Dear all,
I just bought a AX6000/RBK852 (RBK850/RBS850) with the lattest firwmare V3.2.16.6 and I need to have telnet access to be able to change Guest Network IP Range.
In the http://orbilogin.com/debug.htm it is not possible to enable Telnet access anymore.
There are many other functionnalities not availalbe in the GUI (like separate 2.4 and 5 network or rebooting the satellite...)
Is there any solution?
Thanks and Regards
    • philoouu's avatar
      philoouu
      Luminary
      Thanks for coming back to me.
      This is pretty heavy compared to just enabling telnet on the GUI.
      Do you know if there is anything available on Mac ?
      Thanks
      • Anonymous's avatar
        Anonymous
        Not aware of any other way to enable telnet on the new units.
        Virtual machine with windows or linux will do it for you :)
