tg12422455
Oct 29, 2024Aspirant
AX600/RBK852 - is it possible to disable SSID broadcast on the main network?
Brand new system, firmware was upgraded to the latest (V7.2.6.31_5.0.24). Everything works fine, but I want to disable broadcast of SSID of the main network. Going through various web searches, it points me to orbilogin.com, Advanced tab, Setup, Wireless Setup, and unchecking "Enable SSID Broadcast" checkbox. However when I navigate to this area, the option does not appear.
I was able to find screenshots that show a web interface that looks identical to mine, but with the "Enable SSID Broadcast" option.
Also, on the Advanced tab default view, there is a section called "Main Network" which has the detail "Broadcat Name: On". This seems to imply there is (or was) an option to toggle. it.
Does anyone know if the option was available on Orbi and then removed (if so is the reason known)? Are there other models outside of AX600/RBK852 that allow you to turn off broadcast?
Main WIFI radios can not be disabled on Orbi MESH systems. Would cause RBS to disconnect. Intended design of Orbi MESH systems is to have wifi running 24/7.
That information may pertain to non mesh router systems.
- tg12422455Aspirant
Not looking to disable the Wifi - just the broadcast of the SSID. This is fairly common feature that has existed for over 20 years.
Yes existed on NON Mest systems. Not supported on MESH systems.
