ScottinAustin
Apr 29, 2024Aspirant
AXE11000 RBSE960 System receives 400 Bad Request while appying static IP address
I am trying to add some static IP address reservations. In the menu Advanced -> Setup -> LAN Setup, I have added the devices to the list of static IP Address Reservations. When I Click on the APPL...
ScottinAustin
Thanks for your thoughts and time.
Strangely the modems are set up to auto update firmware and they report the following (image). As for the device names, they are something like NAS Port1 and NAS Port2. How do I manage them one at a time? Through their assigned IPs? I currently log in using the XXX.XXX.1.1 IP.
Apr 29, 2024Guru - Experienced User
Sometimes NG doesn't put up newer FW for auto updates. Users can try this process outlined in the PDF:
- ScottinAustinApr 29, 2024Aspirant
Tried a couple more things.. I deleted the devices I tried to add, and the APPLY still fails with a 400. So, I'm sort of stuck where I can't add, nor delete devices. I will try to reboot (cord pull) each Orbit one at a time. When I logged into one of the Satellites directly, I could not see a menu option to reboot it, just Firmware update and one other option, then logoff.
- FURRYe38Apr 29, 2024Guru - Experienced User
Other would be a factory reset and setup from scratch. Possible RBR could be is some bad state on the WEB page. Should clear that out:
