JaxSully's avatar
Feb 09, 2022
AXE11000/RBRE963 RBS Static IP
All,
Just purchased and installed the AEX11000 and converted from Nighthawk X10 with MOCA backhaul to Netgear AP's. First I love it and will try to put as much into the community as I take out.
I did a search on this topic but didn't get any hits.
For those who have multiple RBS devices does the RBR DHCP those devices or hold static IP addresses without being in the reservation table? If the RBR is not reserving behind the scenes do you assign static IP's to the RBS as best practice?
Thanks,
JAX
  • RBS don't support setting of a static IP address on the RBS themselves. If you want a set IP address to be assigned to the RBS, then you'll need to input a IP address reservation ON the RBR for each RBS. Something that is recommended. I do this as well.
1 Reply
  • FURRYe38's avatar
