dcash4242
Jul 06, 2025Aspirant
Backhaul poor out of nowhere
I have a 3 satellite (one router) setup. all 3 satellites are more than 30 ft from the router. The setup has been working fine up until about a week ago and now one of my satellites is getting only g...
dcash4242
Jul 07, 2025Aspirant
2 of my satellites are 750 (firmware: 4.6.9.11)
1 of them is a 760 (firmware: 6.3.8.5)
I've tried swapping the satellites around but none of them will pull more than 130mbps in that room anymore (and they all work fine in my other locations).
michaelkenward
Jul 07, 2025Guru - Experienced User
dcash4242 wrote:1 of them is a 760 (firmware: 6.3.8.5)
Do you check the compatibility list?
Which Orbi routers and satellites are compatible? - NETGEAR Support
I see no indication that the RBS760 will work with the RBR750.
And that list says it was last updated today!
- dcash4242Jul 07, 2025Aspirant
From a compatibility standpoint, it's been working just fine (getting 400mbps+) since October until about a week ago so this is what has me stumped. Why the sudden change? I could see this being an issue if it started slowing down sooner than this, but to run for 8 months with no issue and then hit the brakes out of nowhere is mind boggling.
