UrbanL's avatar
UrbanL
Guide
Apr 04, 2020
Bad connection to Orbi RBS850 satellite
Hello I bought an Orbit RBK853 (with RBR850 and RBS850) before Christmas 2019. I'm about to throw the device out and buy another product, because I have several problems so far and still no solution.
a) the Netgear support is an endless loop I tried 3 times over 40 min at different times and now I have given up. I am already quite annoyed about the manufacturer and product.
b) I have a signal strength of -50 dBm when measuring the network quality, which I find very low when I am about 2m away from the device. Is this normal?
c) in addition (same distance approx. 2m) the signal breaks off from time to time while gaming. It's not my network provider's fault, because my computer, which is connected via LAN cable, can surf perfectly.
The only thing stopping me from throwing the device out is the price and the effort for new installation. Possibly the device is also simply defective - I speak parallel with my handler.
With the problems I have (quality) I can't recommend this part. Also here with AX Forum you can not select the product.
Some technical information: Firmware V3.2.10.11, 5GHz, Channel 8 or if you need more info please contact me.
best regards Urban
  • Any older CAT5 cabling, I would upgrade for sure. CAT6 is mimimum now days.
    Glad the system is working now. Please mark your thread as solved so others will know.
    Enjoy. :smileywink:
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
    Is the Orbi system operating in Router or AP mode?
    IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    https://www.youtube.com/watch?v=ePZSc7vnRlQ
    Try sending a forum Moderator a PM if you want NG support help.
    Blanca_O
    ErnestTheGreat
    Ask about an RMA if one is needed...
    • UrbanL's avatar
      UrbanL
      Guide
      Thanks for your fast reply - I try to anwser them
      1. What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
      UL: the Manufaktur is arcadyan model vrv9519 labled by my telco provider swisscom
      2. Is the Orbi system operating in Router or AP mode?
      UL: no it is router mode - and I connected it to my router from my telefon company -> might this be a / the problem?
      3. What is the size of your home? Sq Ft?
      UL: about 3000 SqFt (=280sqm - but I'm not using it for all sofar).
      4. What is the distance between the router and satellite(s)?
      UL: 30 ft = 10meter
      5. What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on
      UL: not sure - just found in Orbi-Mob-App 8 and 48
      6. 2.4Ghz and any unused channel on 5Ghz.
      UL: ??
      7. Any Wifi Neighbors near by? If so, how many?
      UL: yes but actually quit far away. I usually see about 4-6 other wifis
      8. IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes.
      UL: IPv6 is currently disabled - should I turn it on?
      best regards
      Urban
