tigerisak
Nov 26, 2023Guide
Bang & Olufsen multi room and Netgear Orbi RBR850
I have issues getting Bang & Olufsen multi room to work with my wireless products connected to RBR850 and its connected satellite. Bang & Olufsen is stating that this is a known issue and that Netgear...
tigerisak
Nov 28, 2023Guide
The solution is working great with the wired devices. Spotify Connect and all services are working fine with multi-room and when I "expand" the sound to the other device that works with all the devices that are hardwired. So I guess it has nothing to do with the switch in the basement? It's only for the wifi devices. The sound start playing on the "master" device but when I try to expand to another device - nothing. The sound is only playing on the master device.
tigerisak
Nov 30, 2023Guide
Please advice.
- tigerisakDec 10, 2023Guide
Anyone in this community that could help?
- kolellaDec 11, 2023Apprentice
The problem is already 3 years old and NOT solved ... (https://community.netgear.com/t5/Orbi/Netgear-RBK853-Bang-Olufsen-Multiroom/td-p/2023235)
