tmdefaultuser
Jun 11, 2025Aspirant
Basically it randomly is unable to “ping” the server
I am having the exact same issues that bodger47 is having. Basically it randomly is unable to “ping” the server. I’ve done a hard reset on my system to original default settings. Re-installed my orbi...
tmdefaultuser
CAT6A is wired thru the entire house.
And the internet works fine until it doesn’t. Started about a week ago where the internet randomly cuts out.
- FURRYe38Jun 11, 2025Guru - Experienced User
What server are you trying to ping?
What devices are you using to connect and ping?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Happens with IPv6 enabled or disabled on the RBR?
Happens using ISP DNS or custom DNS?
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed?
Turn off and unplug modem.
Turn on computers and rest of network.How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
