Jonnyappleseed
Oct 31, 2022Follower
Best modem?
I have a RBR750 with one satellite and I want to ditch my Comcast modem and get something from Netgear....appreciate the suggestions.
Check with the ISP to see what is supported on there network.
NGs CM series of modems are pretty good.
The CM2000 is currently the top of the line for xfinity if you're looking modem only
If you're needing modem/voice, then the cm2050v is the voice version.
If you don't need 2.5gig ports, the cm1000, cm1100, cm1200 are all rated for gigabit speed and are docsis 3.1 devices
