Need-WIFI
Apr 24, 2022Follower
Best way to wire AXE11000 satellites, switchport or direct between devices?
Have the 3-unit package (RBKE963) with main WAP and 2 satellites. Have the option to connect the satellites directly to the ports on the back of the main WAP. Also have the option of pugging the main WAP and the 2 satellites into switchports on a separate vlan. Is there any benefit to wiring them one way vs the other?
Orbi routers expect the satellites to be connected through the router LAN ports. That's the way they are designed.
