KG_RBR750
Oct 04, 2022Aspirant
block wifi on schedule on RBR750
The schedule is not working; it did before, but I'm not sure if it was before firmware update to V4.6.9.11_2.3.5
I want wifi to be blocked from 11:15pm to 6am every day. I checked to be sure time/dst is correct.
Thoughts? Thank you.
Seems to be a new issue in FW:
We've made NG aware of it.
- KG_RBR750Aspirant
Thank you - I guess I should roll back to previous firmware? How?
You can if previous FW version worked.
What version had you been using?
Same way as you manually update FW. Download the files to a PC and send to the RBS/RBR web page. RBS first then RBR lastly. Though you might leave the RBS were there at and just downgrade the RBR. RBS should continue to work after the RBR is downgraded.
