romainvallee
May 26, 2025Aspirant
Blocked devices
Hello, I installed an Orbi RBK852 a little over a week ago. Last Friday, it started blocking all devices. I had to reset it and reset everything. It worked fine this weekend until today when it st...
romainvallee
Jun 27, 2025Aspirant
Problem solved. It was an application that made it look like an attack and Armor was blocking everything. UPnP wasn't enough, I had to manually do the port forwarding for this application.
Jun 27, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
