Surfer10k's avatar
Surfer10k
Bridge mode and AXmode
Hi everyone,
I have the Orbi RBR850 set (2 satellites)
My problem is the that my IP standard modem/router uses 192.168.178.x as its ip address base.
The Orbi uses 192.168.1.x
I have switched wifi off on the IPs modem/router. But it still generates ip addresses for equipment that is connected by ethernet.
I have tried switching off DHCP in the router itself but then none of my equipment is getting IP addresses anymore. EG the Orbi is not giving IP addresses to this equipment.
What I wanted to do is get the ORBI to hand out IP addresses based on 192.168.178.x But I cannot see how to do this in The ORBI. Is it not possible?
I think that another option would be to put the ORBI in bridge mode. It is essential though that AX mode not be enabled as this is creating problem's with some of my equipment. Eg Foscam IP camera and RIng doorbell
Any help would be appreciated.
THX
  • I decided that getting into DMZ etc was a little above my paygrade đŸ˜
    I set the obi to AP mode. This solved my problem. The Orbi is still accssible via the app. and all of my devices are now on one network.
    Thanks for the help.
  • michaelkenward's avatar
    michaelkenward
    This is a classic case of "double NAT".
    As you have discovered, two routers on your network can cause headaches. For example, you can end up with local problems with address on your network. Among other things, the other router can misdirect traffic to addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
    This explains some of the other drawbacks.
    What is Double NAT? | Answer | NETGEAR Support
    Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
    My NETGEAR or Orbi router is connected to an ISP gateway or another router, and it's causing double NAT problems. How do I fix them? - NETGEAR Support
    But that has its own drawbacks:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. But some Internet service providers, such as BT in the UK, supply modem/routers that won't work in bridge mode.
    This does not disable the first router.
    Not sure that bridge mode is available there. (That term means different things depending on the context.) Perhaps you mean AP mode.
    Are you sure that these problems are not the result of the double NAT clash?
    There is another option, put the Otbi into the "DMZ" for the anonymous modem/router.
    Set the modem/router with a local IP address that does not clash the Orbi. (I opted for 192.168.2.1.) Then look at whatever IP address the modem/router has allocated to the Orbi and put that as the "DMZ" in your modem/router.
    I left everything else untouched.
    You will still be able to access the controls of the modem/router through its IP address while the GUI for the Orbi is still there on its local address.
    • Surfer10k's avatar
      Surfer10k
      Sounds like what I am looking for. Will let you know how it worked.
      thx
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello Surfer10k ,
    Welcome to the NETGEAR Community!
    I understand that you would prefer to have all your devices on the same network which in this case is  ".178". Please switch your Orbi to AP mode and turn off the wireless signal from your ISP modem/router. Ensure that your modem/router is in router mode and using "DHCP".  This configuration will allow the modem/router to give the desired IP address to your end devices while using the Orbi extended mesh network for wireless signal coverage.
    (Please note to disable your wireless signal on your ISP modem/router, you may have to toggle a setting called "Disable SSID Broadcast.)
    Best,
    Kevin
    Community Team
      Surfer10k
      Thanks. I am going to try the offered solutions and will the forum know what worked for me.
      michaelkenward
      That's the easiest option, especially with Orbi routers. They don't have some of the fancy options of other kit.
      Of the options available with two routers, I'd put them in this order of simplicity:
      • Bridge mode for the modem router (not possible with some hardware)
      • AP mode for the second router (loses some of its features)
      • Second router in DMZ zone of first router (too complicated by far)
