titaniumrx8
May 31, 2021Apprentice
Bryant Connex thermostat won't connect to Orbi RBS753
The Bryant Connex thermostat is the same as Carrier Infinity and only works at 2.4ghz. Had no issues connecting to the Netgear Nighthawk which I replaced with the Orbi. Suggestion on this forum t...
- Jun 01, 2021
Turn OFF all RBS to help elimiate seeing to many SSID names.
Disable AX mode on the RBR:
Set CTS values to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings. Save settings and apply.
If the Controller is taking 20 minutes to report back that it can't connect, this would not be a Orbi problem. Contact the Mfr about this. Shouldn't take that long. My NEST report with in seconds if it can't connect for some reason.
May 31, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- titaniumrx8May 31, 2021Apprentice
Will repost. Thanks.
- FURRYe38May 31, 2021Guru - Experienced User
