Just a quick follow-up to close this thread. The solution proposed by @plemans worked! The page now reads: "Cable Connection Status: Good" in green. Also, no warnings or criticals in the event log since January 26th, when the splitter was installed. No more connection issues either. Everything has been rock-solid since then.
Cable Connection status / diagnostic, as of 2/1/2023:
| CANCEL APPLY |
| Cable Diagnostic | | | Status: Good | | Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info. | | Internet Access: | | Downstream Status: | | Upstream Status: | | | | | Refresh Save Cable Diagnostic Info | |
| | | Advanced Information | | | Frequency Start Value | | | This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | | | Starting Frequency | |
| | | Startup Procedure | | | Procedure | Status | Comment | | Acquire Downstream Channel | 405000000 Hz | Locked | | Connectivity State | Ok | Operational | | Boot State | Ok | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | honorMdd(4) |
| | | Downstream Bonded Channels | | | Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectable | | 1 | Locked | QAM 256 | 1 | 405000000 Hz | 5.1 dBmV | 40.3 dB | 0 | 0 | | 2 | Locked | QAM 256 | 2 | 411000000 Hz | 5.4 dBmV | 40.3 dB | 0 | 0 | | 3 | Locked | QAM 256 | 3 | 417000000 Hz | 5.6 dBmV | 40.9 dB | 3 | 0 | | 4 | Locked | QAM 256 | 4 | 423000000 Hz | 5.9 dBmV | 40.3 dB | 5 | 0 | | 5 | Locked | QAM 256 | 5 | 429000000 Hz | 6.0 dBmV | 40.3 dB | 0 | 0 | | 6 | Locked | QAM 256 | 6 | 435000000 Hz | 6.3 dBmV | 40.3 dB | 0 | 0 | | 7 | Locked | QAM 256 | 7 | 441000000 Hz | 6.5 dBmV | 40.9 dB | 55 | 0 | | 8 | Locked | QAM 256 | 8 | 453000000 Hz | 6.5 dBmV | 40.3 dB | 11 | 22 | | 9 | Locked | QAM 256 | 9 | 459000000 Hz | 6.3 dBmV | 40.3 dB | 0 | 0 | | 10 | Locked | QAM 256 | 10 | 465000000 Hz | 6.4 dBmV | 40.3 dB | 7 | 0 | | 11 | Locked | QAM 256 | 11 | 471000000 Hz | 6.4 dBmV | 40.3 dB | 0 | 0 | | 12 | Locked | QAM 256 | 12 | 477000000 Hz | 6.5 dBmV | 40.3 dB | 1 | 0 | | 13 | Locked | QAM 256 | 13 | 483000000 Hz | 6.4 dBmV | 40.9 dB | 0 | 0 | | 14 | Locked | QAM 256 | 14 | 489000000 Hz | 6.5 dBmV | 40.3 dB | 0 | 0 | | 15 | Locked | QAM 256 | 15 | 495000000 Hz | 6.5 dBmV | 40.3 dB | 0 | 0 | | 16 | Locked | QAM 256 | 16 | 501000000 Hz | 6.5 dBmV | 40.3 dB | 1 | 0 | | 17 | Locked | QAM 256 | 17 | 507000000 Hz | 6.5 dBmV | 40.3 dB | 0 | 0 | | 18 | Locked | QAM 256 | 18 | 513000000 Hz | 6.5 dBmV | 40.3 dB | 0 | 0 | | 19 | Locked | QAM 256 | 19 | 519000000 Hz | 6.6 dBmV | 40.3 dB | 1 | 0 | | 20 | Locked | QAM 256 | 20 | 525000000 Hz | 6.6 dBmV | 40.3 dB | 0 | 0 | | 21 | Locked | QAM 256 | 21 | 531000000 Hz | 6.6 dBmV | 40.3 dB | 0 | 0 | | 22 | Locked | QAM 256 | 22 | 537000000 Hz | 6.6 dBmV | 40.3 dB | 1 | 0 | | 23 | Locked | QAM 256 | 23 | 543000000 Hz | 6.6 dBmV | 40.3 dB | 0 | 0 | | 24 | Locked | QAM 256 | 24 | 549000000 Hz | 6.6 dBmV | 40.3 dB | 3 | 0 | | 25 | Locked | QAM 256 | 25 | 555000000 Hz | 6.5 dBmV | 40.3 dB | 0 | 0 | | 26 | Locked | QAM 256 | 26 | 561000000 Hz | 6.8 dBmV | 40.9 dB | 1 | 0 | | 27 | Locked | QAM 256 | 27 | 567000000 Hz | 6.8 dBmV | 40.3 dB | 3 | 0 | | 28 | Locked | QAM 256 | 28 | 573000000 Hz | 6.8 dBmV | 39.8 dB | 2 | 0 | | 29 | Locked | QAM 256 | 29 | 579000000 Hz | 6.6 dBmV | 40.3 dB | 4 | 0 | | 30 | Locked | QAM 256 | 30 | 585000000 Hz | 6.9 dBmV | 38.9 dB | 4 | 0 | | 31 | Locked | QAM 256 | 31 | 591000000 Hz | 7.0 dBmV | 38.9 dB | 5 | 0 | | 32 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| | | Upstream Bonded Channels | | | Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 4 | 5120 Ksym/sec | 16400000 Hz | 46.5 dBmV | | 2 | Locked | ATDMA | 3 | 5120 Ksym/sec | 22800000 Hz | 47.0 dBmV | | 3 | Locked | ATDMA | 2 | 5120 Ksym/sec | 29200000 Hz | 47.3 dBmV | | 4 | Locked | ATDMA | 1 | 5120 Ksym/sec | 35600000 Hz | 47.8 dBmV | | 5 | Locked | ATDMA | 5 | 1280 Ksym/sec | 39600000 Hz | 48.3 dBmV | | 6 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 7 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 8 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| | | Downstream OFDM Channels | | | Channel | Lock Status | Modulation/Profile ID | Channel ID | Frequency | Power | SNR/MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords | | 1 | Locked | 3 | 45 | 690000000 Hz | 7.8 dBmV | 41.6 dB | 1108~2987 | 0 | 0 | 0 | | 2 | Not Locked | 0 | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0~4095 | 0 | 0 | 0 |
| | | Upstream OFDMA Channels | | | Channel | Lock Status | Modulation/Profile ID | Channel ID | Frequency | Power | | 1 | Not Locked | 0 | 0 | 0 Hz | 0.0 dBmV | | 2 | Not Locked | 0 | 0 | 0 Hz | 0.0 dBmV |
| | | Current System Time: Wed Feb 1 09:43:16 2023 | | | System Up Time 6 days 00:41:41 | |
Events log for the last week:
| Clear Log Refresh |
| | | Time | Priority | Description | | Jan 26 2023 09:03:30 | Alert (2) | CM Certificate Error | | Jan 27 2023 07:21:31 | Notice (6) | DS profile config update. DS Chan ID: 45. | | Jan 28 2023 05:01:49 | Alert (2) | CM Certificate Error | | Jan 29 2023 20:40:04 | Notice (6) | DS profile config update. DS Chan ID: 45. | | Jan 30 2023 05:01:46 | Alert (2) | CM Certificate Error | | Feb 01 2023 09:25:25 | Notice (6) | DS profile config update. DS Chan ID: 45. |
Power ranges from 5.1 to 7.0 dBmV now. SNR very stable from 38.9 to 40.3. I am also attaching a screenshot the tech gave me which shows the "Flux" since I don't see that listed anywhere.
Thank you both so much for your help with troubleshooting my issue. It is greatly appreciated.
