OdiousUmbra
Jan 23, 2023Tutor
Cable connection issues on Comcast/Xfinity with CBR750
Hello. I am using the Orbi CBR750 modem/router mesh combo with one RBS750 satellite, and Comcast/Xfinity as my ISP. Starting this morning, I have been experiencing strange issues with my connection. ...
- Jan 24, 2023
Other than the power being too high, should be ok other wise.
Have the tech review any Errors, Criticals or Warnings seen in the events log page as well.
As about a in-line attenuator to help with power levels.
Show him this:https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Feb 01, 2023Guru - Experienced User
Looks pretty rock solid!
Glad you got it working well again
Enjoy. 📡
