Mkstretch
Jul 11, 2025Aspirant
Can backhaul be done without having all orbi’s connected to the same switch?
Great thread!
RBR850 + RBS850: Ethernet Backhaul in AP Mode - Horrible Performance or bad connection | NETGEAR Communities
I just purchased these Orbi’s. I’m looking to do wired backhaul. I’m...
- Jul 11, 2025
RBS can be connected directly behing the RBR or to a switch that is also connected behind the RBR. Just know that any RBS that is ethernet connected, need to be always connected behind the RBR, along with any Switches that a RBS maybe connected too, these switches needs to be connected behind the RBR.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 🛰️
Non managed switches are recommended for ease of setup and configuration with RBS.
NETGEAR GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Can also mixed RBS connections as well, one ethernet connected, one wirelessly connected to the RBR.
Mkstretch
Jul 15, 2025Aspirant
Do I need to plug my switch into the Orbi router lan port. As well as plug Orbi router yellow port into my fios router?
Jul 16, 2025Guru - Experienced User
For Ethernet connected RBS and using a switch, please refer to this guide:
Mkstretch wrote:Do I need to plug my switch into the Orbi router lan port. As well as plug Orbi router yellow port into my fios router?
