jlapl169
Dec 27, 2022Follower
Can I add a new RBS750 to my older RBK53 Mesh system?
I am trying to decide to add another satellite to my current mesh setup. Can I add a new RBS750 to my older RBK53 Mesh system? If so, is it easy to get them all setup together?
No. Not compatible. Sorry
as CrimpOn says, no, it won't work.
But there's a bunch of renewed 40 and 50 series orbi's on amazon. Cheaper than buying the satellite by itself and then you have a backup router in case the main router ever goes bad and then you have a bunch of satellites you can't use.
