Marian_P's avatar
Oct 13, 2025
Can I change the wifi channels on the Orbi Mesh/RBK862SB?
Hey, I'm considering changing the router. The current model is a 2-pack Deco X60/AX5400. While it works most of the time but the smart devices keep disconnecting and connecting. This Christmas, I'll add more smart cameras/sensors. I'm afraid it's going to be a nightmare for X60. so I have to think early. From what I have experienced with Deco, smart devices work well when the 2.4Ghz stays on channel 11/20mhz, but it keeps changing its mind:-(. Does RBK862SB allow me to manually change the wifi channels, especially for the 2.4ghz band?
Thanks.
    Yes, you can set up fixed channels for both the 2.4 ghz and 5 ghz client radios.  There is a control to enable (or disable) 20/40 Mhz coexistence, but you cannot set up the channel to only use 20 Mhz.  (The control either enables 40 Mhz or both 20/40).
    You won't have control over the radio used by the mesh backhaul (used to connect the satellites to the router).
    More details are here:
    • https://www.downloads.netgear.com/files/GDC/RBK863S/RBR860_RBS860_UM_EN.pdf
1 Reply
  • StephenB's avatar
