atomarchio
Sep 03, 2020Tutor
Can I use AX4200 to tell me if kids have logged in online with their chromebooks?
I just bought the Orbi AX4200 wifi router system. Can the Orbi app tell me if my kids have logged into their chromebooks online just before school? I see the device list but not exactly how thi...
Mstrbig
Sep 03, 2020Master
The Orbi app and GUI has settings to do what you ask. I'm not sure shuuting down would keep the info, as Orbi, unlike Veop, does not visibly retain disconnected devices.
Did you read the manual to see if it covers it?
- atomarchioSep 03, 2020Tutor
Yes, there is nothing specific in the manual that refers to what I am looking for.
I am trying to see if there is way to figure out when my kids chromebooks log onto the wifi each morning.
perhaps someone else has a solution and would be willing to share. thanks.
- FURRYe38Sep 03, 2020Guru - Experienced User
Be sure to check out the Orbi AX forum for questions and infornation:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
atomarchio wrote:Yes, there is nothing specific in the manual that refers to what I am looking for.
