dohc97
Apr 13, 2021Follower
can not connect to VPN
Just got my Orbi RBR750 last week. I can connect to vpn to login to my work using a wired connection. when I am on a wifi connection, I can not connect to my vpn. A workaround I found is to connect to vpn first when I am on wired connection, unplug the wire, and connect to my wifi. I can not connect/disconnect and reconnect again to my vpn. Any settings I should check on the Orbi?
1 Reply
Is the Orbi system operating in Router or AP mode?Does this happen on your one device or others as well?
