billhyd
Jan 15, 2023Follower
can not see whats connected to rbs350 satellite
i just bought a RBR750 and 2 of RBS350 came as a set, its all hooked up and works good, but i can not see whats connected to the rbs350 unless i log into them. firmware for the rbr750 isV4.6.14.3 and the rb350 is V4.6.3.16, from what i have seem it seems like it is a firmware issue i was going to to see if there was a newer version to update it to, but all there is a older version than what i have not sure what to do ?
thank you for any help on this.
1 Reply
You need to update the RBS to same version of FW:
Be sure to remember to update the RBS first, then RBR lastly.
