case44
Jan 20, 2026Aspirant
Cannot access Orbi AX4200 anymore
I have the Orbi AX4200 WiFi 6 High-Performance Router (RBR750) I used to be able to either go to orbilogin.net or use the Orbi Android application to manage the device. Now, even after mult...
Jan 20, 2026Guru - Experienced User
So using a wired PC and web brower pointed at 192.168.1.1 isn't getting the RBRs web page to come up?
If not, then you might do a factory reset on the RBR by pressing the reset button in back for 15 seconds then release. Give about 5 minutes then with one wired PC and web browser, walk thru the setup wizard:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
