case44
Jan 20, 2026Aspirant
Cannot access Orbi AX4200 anymore
I have the Orbi AX4200 WiFi 6 High-Performance Router (RBR750) I used to be able to either go to orbilogin.net or use the Orbi Android application to manage the device. Now, even after mult...
case44
Correct. I'm wired to the Orbi RBR750 and 192.168.1.1 isn't getting the web page to come up.
I've got AT&T Fiber Model: BGW320-500
I've got the wifi turned off on it. It's directly connected to the Orbi for my home network.
I was hoping to avoid a factory reset, but looks like that's the route I need to take.
- FURRYe38Jan 20, 2026Guru - Experienced User
Your ISP modem already had a router built in. Might check the connecting PCs IP address it gets from the Orbi router and see if maybe the IP address changed to a 10.x something address. if not, then Ya, reset will be needed.
FYI,
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- StephenBJan 20, 2026Guru - Experienced User
Before you do a massive reconfiguration, you should check that your PC IP address is on the 192.168.1.x subnet. If it says something else, post back the address. Note that the LAN addresses are private (not internet routable), so it is safe to post them.
FWIW, double-NAT isn't as dreadful as some here always say, so if your internet has always worked before, then there is no reason to change anything.
