case44
Jan 20, 2026Aspirant
Cannot access Orbi AX4200 anymore
I have the Orbi AX4200 WiFi 6 High-Performance Router (RBR750) I used to be able to either go to orbilogin.net or use the Orbi Android application to manage the device. Now, even after mult...
case44
Thanks, the IP of my Orbi (on my ATT) is 192.168.1.64.
The IP of my home machine is 10.0.0.2 (on the Orbi).
I tried 10.0.0.1 and 10.0.0.254 as well
When I go to orbilogin.com I get ERR_CONNECTION_REFUSED
Jan 20, 2026Guru - Experienced User
case44 wrote:the IP of my Orbi (on my ATT) is 192.168.1.64.
Then 10.0.0.1 should connect you to the Orbi's web page, and 192.168.1.1 should connect you to the AT&T gateway's web page.
case44 wrote:When I go to orbilogin.com I get ERR_CONNECTION_REFUSED
Are you also getting this with 10.0.0.1?
A reset might be needed.
