JeffP217
Feb 06, 2022Tutor
Cannot connect NordicTrack iFit console (model s10i) to Orbi WiFi 6 mesh router
Set up my new Orbi Mesh Router wtih two satellites - everything in the house connected without issue...except my NordicTrack iFit s10i console (which I believe is a highly modified low-spec Android t...
- Feb 09, 2022
I've seen some older or IoT devices that struggle with the AX spec. Its supposed to be backwards compatible but sketchy coding on the older or IoT devices can have issues.
Does it connect if you disable AX?
Are you using WPA3? Try disabling that and using WPA2
Feb 07, 2022Guru - Experienced User
The tplink is a modem/router combo. Turning off the wifi on it doesn't disable its router function and it causes a double nat.
some devices tolerate a double nat better than others.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- JeffP217Feb 08, 2022Tutor
Thank you - so I have my TP-Link set up with PPPOe and the Orbi in AP mode with everything working...except that bloody iFit device. I tried to set up TP-Link as a Bridge and use Orbi in router mode but could not get that working. I just ran a full Route This test on the netword and it is detecting that I still have a double NAT issue despite the set up. Not sure where to go from here to address the double NAT issue and see if that resolves the iFit device issue. To complicate things, since putting Orbi into AP mode, I can no longer access it from orbilogin.com so I can't even get to the control panel to change it back to router mode or any other setting (the phone app is pretty light on with the advance settings).
And I should correct - I have the Orbi RBR850 hub + two satallites - for some reason that was not an option in the dropdown when setting up this question/post
On last update - I have also tried the option 2 - DMA approach but still getting double NAT - first two pings on a tracert are:
1 10 ms 3 ms 2 ms 10.0.0.1
2 6 ms 7 ms 15 ms 192-168-1-1.tpgi.com.au [192.168.1.1]
