JeffP217
Feb 07, 2022Tutor
Cannot connect NordicTrack iFit console (model s10i) to Orbi WiFi 6 mesh router
Set up my new Orbi Mesh Router wtih two satellites - everything in the house connected without issue...except my NordicTrack iFit s10i console (which I believe is a highly modified low-spec Android t...
- Feb 09, 2022
I've seen some older or IoT devices that struggle with the AX spec. Its supposed to be backwards compatible but sketchy coding on the older or IoT devices can have issues.
Does it connect if you disable AX?
Are you using WPA3? Try disabling that and using WPA2
JeffP217
Feb 15, 2022Tutor
Yay! - Disabling AX on the Orbi router and the device connected no problem. A solution! Thank you so much.
Feb 15, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
