JeffP217
Feb 06, 2022Tutor
Cannot connect NordicTrack iFit console (model s10i) to Orbi WiFi 6 mesh router
Set up my new Orbi Mesh Router wtih two satellites - everything in the house connected without issue...except my NordicTrack iFit s10i console (which I believe is a highly modified low-spec Android t...
- Feb 09, 2022
I've seen some older or IoT devices that struggle with the AX spec. Its supposed to be backwards compatible but sketchy coding on the older or IoT devices can have issues.
Does it connect if you disable AX?
Are you using WPA3? Try disabling that and using WPA2
SigueSigue
Aug 03, 2022Tutor
what a rubbish solution from ifit - doing all that whitelisting issn't doing a damn thing if it won't join the wifi network.
My orbi network doesn't do 2.4ghz very well. no 2.4 on the sattelites so my eliptical is doing its hardest to connect to the router because the ifit itself only supports 2.4
if the ifit would support 5ghz or if the orbi sattelites would do 2.4ghz then there would be no issue
this reddit post seems the best description of the issue
https://www.reddit.com/r/nordictrack/comments/qpjbl7/nordictrack_s22i_studio_bike_wifi_connection/
Aug 05, 2022Guru - Experienced User
Something to contact the mfr of your iFit device for help and support regarding there product. Seems like it even has problems with Googles MESH systems as well.
