FrancisduBois's avatar
Jun 17, 2024
Cannot connect to ORBI Router RBR850 and 6 Connected Satellites
I have an ORBI Router RBR850 and 6 Connected Satellites in the house (Ethernet connected).
Is there a limit on the number of Connected Devices (Sonos, MacBooks, etc.) ? We are often kicked out of the wifi or cannot connect with our i-Phones and it is impossible to join any of the 6 satellites or the router.
Yes I restarted the Orbi router (and did a reboot) and wifi and our i-Phones as well, several times, to no avail.
I believe they are all linked via daisy chain (how to check? I think someone told me that I could not use the Orbi app (http://orbilogin.net/start.htm) and needed to set it up differently, but I don't remember).
Should I go for a factory reset of the router and all of the satellites?
Thanks so much,
Francis
1 Reply
