ScottNH
Mar 06, 2026Aspirant
Cannot Connect to Orbi
We had a power glitch, and after recovery, I suddenly cannot connect to my RBRE960 router (or satellites). The router is working, and I have both WiFi and internet, but whenever I try to connect to ...
- Mar 08, 2026
The nuclear option worked. Have no idea why it was necessary, but resetting to factory default and climbing my way back to my own settings finally worked. Daylight savings time saved me, because everyone was still in bed. "Hey, Alexa isn't working!" Well, almost everyone.
ScottNH
Mar 08, 2026Aspirant
- plemansMar 08, 2026Guru - Experienced User
Glad it fixed it but it sucks when you have to go nuclear. A backup is always a good option to have available. I switch routers enough that its probably only 5 minutes of setup through the gui when I do it.
- FURRYe38Mar 08, 2026Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
