Justbenice
Jun 20, 2021Aspirant
Can't add more than 2 satellite to RBR750 in AP mode and satellite not sync with rbr750
Hello.
I just bought a system with 1 RBR750 and 4 RBS750 . When i setup this systems, if i using router mode in RBR750 then the system work very fine with the whole four satellite and one router, but it stop working or showing only 2 satellite in the RBR750 dashboard, the another 2 satellite are completely drop backhaul with the RBR750, i tried many ways to add another 2 satellite to the system but no luck at all, i tried to reset rbr750, rbs750 hundress time already
The reason why i need to using the RBR750 orbi as AP because i have a very good router already, it stronger and better than the rbr750 in manyway, so i want to keep my old router do the route and the RBR750 mesh system do the wifi only.
Anyone can help me?
PS : Both rbr and rbs750 are in 3.2.18.1 firmware version.
JBN
What is the Mfr and model# of the host router the RBR router is connected too?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteAre you using Dynamic or Static IP addressing for the RBR in AP mode?
- JustbeniceAspirantHi,
My network setup like this :
ISP moderm -> Draytek Vigor 2926
-> Netgear Prosafe Switch 24 port (unmanaged and cheapest one) -> Rbr750 at AP dynamic IP .
I connect 3 of the satellite to the switch by wired and one near the RBR750 with wireless.
I can see all those satellite in RBR750 admin page but it doesn't sync.
And i don't know why the satellite3 is do wireless backhaul instead of wire backhaul .
Sorry for my bad English- FURRYe38Guru - Experienced User
To get this working right you need to connect the RBS to the back of the RBR, not in parallel:
