rongerber
Jul 03, 2026Aspirant
Can't attach Orbi Satellite
I am having problems connecting this 6th satellite to my orbit 850 router? What should I do?
Jul 03, 2026Guru - Experienced User
FW on this one RBS the same version as the rest?
What happens if you turn OFF one of the other RBS temporarily?
What is the size of his home in sq feet?
- rongerberJul 04, 2026Aspirant
2500 sq ft home. All are the same version. I will try. thanks.
- FURRYe38Jul 05, 2026Guru - Experienced User
This home made of concrete and steel?
Normal wood and sheet rock home of that size would only need the RBR and just one RBS.
