adzify106's avatar
Mar 05, 2024
Can't get Pixel 8 Pro to work with Orbi
150m2 house with an Orbi RBK853 no other devices having issues.  Did a quick search and apparently there are issues with Pixel phones working on Mesh networks.  I can connect to the network but it is seriously struggling with streaming and buffering even from local NAS.
This speed test was conducted in the main living room approx. 5m away from the Main Router:  https://i.imgur.com/9zfhx4H.jpeg
It seems the issue is the Pixel is struggling to know which Satellite/Base to connect to?
Apparently the resolution is to disable "Fast-Roaming" but I don't think the RBK853 has this option?
Any ideas?
More info and tests here:  https://imgur.com/a/ywDq8gS
UPDATE!! - I just enabled the IoT network and set it to 5Ghz only and it's solved the issue my speeds are over 100Mbps+.  So there must be some issue with the main network side?
  • FURRYe38's avatar
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Something to ask the phone Mfr about.
    • adzify106's avatar
      adzify106
      Guide
      I don't know if you saw the update but I've found a workaround, so the clue to resolving the issue is something about the shared SSID and how the mesh network interacts with the phone.
      • Firmware for the phone is Android 14 running March 5th Feature Release.
      • Firmware for the RBR850 is V7.2.6.21_5.0.20
      • No, wireless only.
      • Channel Configurations are currently:
      RegionAustralia / New Zealand
      2.4 GHz ChannelAuto (2)
      2.4 GHz Wireless mode:Up to 1147 Mbps
      5 GHz Channel36 + 40(P) + 44 + 48
      5 GHz Wireless mode:Up to 2402 Mbps
