BKWayne's avatar
BKWayne
CBR750 Address Reservation and Port Forwarding not working
Model: CBR750
FW: V4.6.14.4
Just got this router today. When I go to set static IPs via Address Reservation I'm hit with "400 Bad Request" and this is occurring with several devices.
When I go to setup port forwarding on those devices, I receive no error, but the list of services remains blank and it appears nothing has gone through.
Have ran a firmware update and reboot. No avail.
  • FURRYe38's avatar
    What browser are you using? Does it happen with a different browser?
    Try a full factory reset and setup from scratch using a web browser and wired PC.
    Be sure to clear out all browser caches before entering the CBRs web page at 192.168.1.1
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
  • CrimpOn's avatar
    CrimpOn
    Are you using the 'pull down' menu to select the service (port) or creating a 'custom' rule?
    Port forwarding is somewhat unique in that there is no "Apply" button at the top of the screen and the router WiFi does not go through a restart as it does with so many other changes. (annoying the heck out of my Alarm system.  "Lost WiFi"  "WiFi Found", both texts and emails.)
