AnthonyL300
Sep 25, 2022Aspirant
CBR750 has become a nightmare! Job at risk! Please help
I just recently moved and have my Orbi CBR750 set up straight from the wall with my coax cable attached to the Orbi is a Netgear Wax206 Access Point (I use for a separate network for my work computer)...
Sep 25, 2022Guru - Experienced User
2 things.
1. you do have a ton of errors in the lines. The logs help confirm line issues but your errors alone are to many.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
2. Whenever you're having issues and you're using multiple devices, simplify for testing. Connect your work pc directly to the orbi and make sure to get that stable first.
AnthonyL300
Sep 29, 2022Aspirant
No amplifiers or anything in between the modem and the wall it's maybe 2 ft away from each other straight from the wall into the CBR750
