1R0N
Oct 25, 2021Tutor
CBR750 Losing Connection daily
I'm hoping someone can help me here. I have an Orbi CBR750 on Suddenlink Internet. I have multiple daily Internet drops and Suddenlink has sent three different techs out. They can't seem to find an...
Oct 25, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the Orbi system been performed since last update?
- Triggs21Oct 25, 2021StarMine does the same thing. It is faulty netgear equipment. Not related to isp at all. Disconnected cbr750 and connected old router to the same line. No drop puts what so ever. Netgear when will you support your customers and address this as a known issue. I shouldnt have to talk to a technician 10+ times for a problem multiple people all of the sudden started having... stand by your word and help us....
- 1R0NOct 26, 2021Tutor
The ISP says the signal and line quality are fine up to the modem now.
I talked to Suddenlink support last night and the tech re-provisioned the modem to be sure that it was properly provisioned.
There are no splitters between the modem and ISP service box.
I have tried three different brand new RG6 Coax cables to the modem to no avail.
The modem has been powered off for at least one minute multiple times.
Not sure what the size of the home has to do with it since this is about cable dropping out at the modem not the wireless, but it is 1475 Square feet.
The only satellite in use is aproximately 40 feet from the modem.
The modem is set to Auto and 48 on 5Ghz. I have tried manually setting channels on both 2.4Ghz and 5Ghz, but again, this is about the signal dropping out at the modem, not the wireless.
We do have neighbors that use WiFi as well, but the signal is negligable, and again, this is about no Internet service, not WiFi dropping out.
I always power the modem off for at least one minute after an update.
I have attached the modem connection status.
- FURRYe38Oct 26, 2021Guru - Experienced User
Well I see some Correctables being logged but not many. Usually Zero is preferred here.
Seems like the power levesl range from 2 to -0.7 which all should be around same range.
Has the CBR still lost connection since ISP re-checked everything?
Yes it has still lost connection several times.
