pbert
Nov 10, 2021Aspirant
CBR750 not connecting to RCN
I just got a CBR750 second hand and am having trouble connecting to RCN. When the router boots up it gets to the final "online" light flashing but that light never turns solid. I've noticed the light below is a neon purple as well.
I'm able to connect to the admin app via ethernet and wifi, but the unit will not connect to the internet.
In the cable connection section of the app it just says "Modem is offline. Please check RF connection."
Any help troubleshooting this issue would be greatly appreciated!
Thanks for the help. RCN had to send a technician out and he said the power levels were a little high (~12 [dBmV I assume]). He was able to get it working, though.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853- pbertAspirant
Thanks for the reply. The coax cable does have a splitter right before connecting to the service box. If I can't get it working otherwise, do you think a female to female adapter would be OK or does it need to be one cable from the service box to the modem? We do not use the other cable running from the splitter it can definitely be removed.
I tried a full power off and power up cycle a few times, but still no solid online light. I also tried upgrading to the latest firmware (4.6.5.8).
Is this the connection status you were referring to?
SpoilerStartup ProcedureProcedure Status Comment Acquire Downstream Channel 363000000 Hz Locked Connectivity State In Progress Not Synchronized Boot State In Progress Unknown Security Disabled Disabled IP Provisioning Mode In Progress Unknown
Downstream Bonded ChannelsChannel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectable 1 Locked QAM 256 17 363000000 Hz 7.5 dBmV 40.9 dB 0 0 2 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 3 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 4 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 5 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 6 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 7 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 8 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 9 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 10 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 11 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 12 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 13 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 14 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 15 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 16 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 17 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 18 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 19 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 20 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 21 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 22 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 23 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 24 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 25 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 26 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 27 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 28 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 29 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 30 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 31 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 32 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0
Upstream Bonded ChannelsChannel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 30350000 Hz 40.5 dBmV 2 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 3 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 4 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 5 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV
Downstream OFDM ChannelsChannel Lock Status Modulation/Profile ID Channel ID Frequency Power SNR/MER Active Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Not Locked 0 0 0 Hz 0.0 dBmV 0.0 dB 0~4095 0 0 0 2 Not Locked 0 0 0 Hz 0.0 dBmV 0.0 dB 0~4095 0 0 0
Upstream OFDMA ChannelsChannel Lock Status Modulation/Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0.0 dBmV 2 Not Locked 0 0 0 Hz 0.0 dBmV
Current System Time: Thu Jan 1 00:11:02 1970System Up Time 00:10:58- FURRYe38Guru - Experienced User
Ya remove the splitter. A barrel connector can work.
Um, you only have 1 channel locked in for both UP and Down. There should be more channels locked in.
Power maybe high on the 1 channel.
You need to contact your ISP and have them check your line and check the connections status page on the CBR. You should have several Download Channels locked in.
