mattr_06
Jun 25, 2023Follower
CBR750 now not working with Xfinity
I'm currently facing persistent internet connection issues with my ORBI CBR750 router, and I'm seeking some guidance or advice from the Netgear community.
To provide some context, I find myself having to restart my ORBI CBR750 router every 24 hours. The primary reason for this constant restarting is that my internet connection frequently drops or slows down to an unbearable speed of under 1Mb. I've taken the necessary steps to resolve this issue, including having an Xfinity technician inspect the lines and verify the signal quality of the modem. Fortunately, the technician confirmed that the signal strength is optimal, and the modem itself is functioning properly.
Despite these troubleshooting efforts, the problem persists. Whenever I reset the ORBI router, the internet connection is restored within approximately 10 minutes. However, frustratingly enough, the issues resurface within 24 hours.
Additional information about my setup:
- Firmware Version: V4.6.14.4_2.3.12
Cable Diagnostic
Status: Good
Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
Internet Access: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
Current time: Sun Jun 25 16:48:32 2023
Startup Procedure
Acquire Downstream Channel: 591000000 Hz Locked
Connectivity State: Ok Operational
Boot State: Ok Operational
Security: Enabled BPI+
IP Provisioning Mode: Honor MDD honorMdd(4)
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM 256 13 501000000 Hz 7.9 40.9 0 0
2 Locked QAM 256 14 507000000 Hz 7.6 40.9 0 0
3 Locked QAM 256 15 513000000 Hz 7.4 40.9 0 0
4 Locked QAM 256 16 519000000 Hz 7.5 40.9 0 0
5 Locked QAM 256 17 525000000 Hz 8.4 40.9 0 0
6 Locked QAM 256 18 531000000 Hz 9.0 40.9 0 0
7 Locked QAM 256 19 537000000 Hz 8.9 40.9 0 0
8 Locked QAM 256 20 543000000 Hz 8.5 40.9 0 0
9 Locked QAM 256 21 549000000 Hz 8.3 40.9 0 0
10 Locked QAM 256 22 555000000 Hz 8.5 40.9 0 0
11 Locked QAM 256 23 561000000 Hz 8.6 40.3 0 0
12 Locked QAM 256 24 567000000 Hz 8.5 40.3 0 0
13 Locked QAM 256 25 573000000 Hz 8.4 40.3 0 0
14 Locked QAM 256 26 579000000 Hz 8.0 40.3 0 0
15 Locked QAM 256 27 585000000 Hz 7.9 40.9 0 0
16 Locked QAM 256 28 591000000 Hz 7.6 40.9 0 0
17 Locked QAM 256 29 597000000 Hz 7.3 40.3 0 0
18 Locked QAM 256 30 603000000 Hz 7.5 40.3 0 0
19 Locked QAM 256 31 609000000 Hz 7.6 40.9 2 0
20 Locked QAM 256 32 615000000 Hz 7.4 40.3 0 0
21 Locked QAM 256 33 621000000 Hz 7.5 40.9 0 0
22 Locked QAM 256 34 627000000 Hz 7.8 40.9 0 0
23 Locked QAM 256 35 633000000 Hz 8.0 40.9 0 0
24 Locked QAM 256 36 639000000 Hz 8.4 40.9 0 0
25 Locked QAM 256 37 645000000 Hz 8.1 40.9 0 0
26 Locked QAM 256 38 651000000 Hz 8.3 40.9 0 0
27 Locked QAM 256 39 657000000 Hz 8.6 40.3 0 0
28 Locked QAM 256 40 663000000 Hz 8.6 40.9 0 0
29 Locked QAM 256 41 669000000 Hz 8.8 40.3 0 0
30 Locked QAM 256 42 675000000 Hz 8.8 40.3 0 0
31 Locked QAM 256 43 681000000 Hz 8.3 40.3 0 0
32 Locked QAM 256 44 687000000 Hz 8.3 40.9 0 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 17 5120 16400000 Hz 47.8
2 Locked ATDMA 18 5120 22800000 Hz 46.5
3 Locked ATDMA 19 5120 29200000 Hz 45.5
4 Locked ATDMA 20 5120 35600000 Hz 45.0
5 Not Locked N/A 0 0 0 Hz 0.0
6 Not Locked N/A 0 0 0 Hz 0.0
7 Not Locked N/A 0 0 0 Hz 0.0
8 Not Locked N/A 0 0 0 Hz 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 3 193 957000000 Hz 7.8 dBmV 42.5 dB 148~3947 0 0 0
2 Not Locked 0 0 0 Hz 0.0 dBmV 0.0 dB 0~4095 0 0 0
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0.0 dBmV
Event Log
Time Priority Description
Jun 25 2023 16:12:25 Critical SYNC Timing Synchronization failure - Loss of Sync
Jun 25 2023 16:12:29 Notice CM-STATUS message sent. Event Type Code: 16
Jun 25 2023 16:12:29 Warning Lost MDD Timeout
Jun 25 2023 16:13:22 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Jun 25 2023 16:13:59 Error Missing Mandatory MDD TLV on primary DS Channel
Jun 25 2023 16:14:18 Critical SYNC Timing Synchronization failure - Loss of Sync
Jun 25 2023 16:14:32 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jun 25 2023 16:14:32 Notice TLV-11 - unrecognized OID
Jun 25 2023 16:14:32 Critical Config File Rejected due to Invalid or Unexpected TLV 11
Jun 25 2023 16:14:35 Critical SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period
Jun 25 2023 16:14:35 Error RCS Primary DS Failure
Jun 25 2023 16:14:58 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jun 25 2023 16:14:58 Notice TLV-11 - unrecognized OID
Jun 25 2023 16:14:58 Critical Config File Rejected due to Invalid or Unexpected TLV 11
Jun 25 2023 16:15:03 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jun 25 2023 16:15:13 Alert CM Certificate Error
Jun 25 2023 16:16:42 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jun 25 2023 16:16:42 Notice TLV-11 - unrecognized OID
Jun 25 2023 16:16:42 Critical Config File Rejected due to Invalid or Unexpected TLV 11
Jun 25 2023 16:16:46 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jun 25 2023 16:16:46 Critical No Ranging Response received - T3 time-out
Jun 25 2023 16:16:57 Alert CM Certificate Error
Your logs are indicating line issues from the isp.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this. - FURRYe38Guru - Experienced User
What Speed Tier package do you pay for UP and Down from the ISP?
Also power is a bit on the high side:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Might ask the ISP to lower the power a bit.
Any Criticials, Errors or Warnings seen in the Event log should be reviewed and resolved by the ISP.
