Retired_Member
Apr 12, 2022CBR750 random disconnects
I have just the one CBR750 modem/router - no additional satellites, etc. Nearly every day at random times, I'll get disconnected and have to reboot the device. I've tried reflashing the firmware ...
Apr 12, 2022Guru - Experienced User
For one the power levels are too low:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
Something that the ISP needs to check on. Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
