skrishnan37
Jun 24, 2020Aspirant
Cell phone calls disconnect when on Wi-fi
I have noticed that if I have my WiFi on my iPhone XS and someone calls , the call gets immediately disconnected. If I try to make a call & the WiFi is on, as soon as someone picks up, the call is dis...
- Jul 26, 2020
I'm embarrassed to say I figured out the problem. It was my phone. I thought it was the router, that had nothing to do with it. Problem solved.
Jun 24, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
