skrishnan37
Jun 24, 2020Aspirant
Cell phone calls disconnect when on Wi-fi
I have noticed that if I have my WiFi on my iPhone XS and someone calls , the call gets immediately disconnected. If I try to make a call & the WiFi is on, as soon as someone picks up, the call is dis...
- Jul 26, 2020
I'm embarrassed to say I figured out the problem. It was my phone. I thought it was the router, that had nothing to do with it. Problem solved.
Jetdrive
Jun 24, 2020Luminary
And conversly, if you turn wifi calling off, do the calls complete normally?
skrishnan37
Jun 25, 2020Aspirant
Exactly. Turn off WiFi, no problem.
- JetdriveJun 25, 2020LuminaryNot exactly. Sometimes there is a setting messed up that turning that feature off and then back on fixes. Just turning off WiFi would not reset the WiFi calling feature - it would just turn off WiFi on the phone.
