skrishnan37
Jun 24, 2020Aspirant
Cell phone calls disconnect when on Wi-fi
I have noticed that if I have my WiFi on my iPhone XS and someone calls , the call gets immediately disconnected. If I try to make a call & the WiFi is on, as soon as someone picks up, the call is dis...
- Jul 26, 2020
I'm embarrassed to say I figured out the problem. It was my phone. I thought it was the router, that had nothing to do with it. Problem solved.
Jun 29, 2020Guru - Experienced User
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
skrishnan37 wrote:
I have noticed that if I have my WiFi on my iPhone XS and someone calls , the call gets immediately disconnected. If I try to make a call & the WiFi is on, as soon as someone picks up, the call is disconnected. Not a problem when the WiFi is turned off. Not a problem when I’m on someone else’s WiFi. Thoughts? Some kind of restriction from the Orbi router? (I’ve had this iPhone for almost 2 years and this is a new problem.)
AT&T fiber optic-dumbswitch-Orbi RBK852 with 2 satellites
