skrishnan37
Jun 24, 2020Aspirant
Cell phone calls disconnect when on Wi-fi
I have noticed that if I have my WiFi on my iPhone XS and someone calls , the call gets immediately disconnected. If I try to make a call & the WiFi is on, as soon as someone picks up, the call is disconnected.
Not a problem when the WiFi is turned off. Not a problem when I’m on someone else’s WiFi.
Thoughts? Some kind of restriction from the Orbi router? (I’ve had this iPhone for almost 2 years and this is a new problem.)
AT&T fiber optic-dumbswitch-Orbi RBK852 with 2 satellites
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-meanWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Any progress on this?
