NetgearAsia
Sep 13, 2025Aspirant
challenge under 750 under AP mode
seek support here about AP mode. I really like the router mode of my 753 package. Now as I want to upgrade my router to 2.5G, I need use a new router to do the network dialing and DHCP and put m...
Sep 13, 2025Guru - Experienced User
Does 5Ghz or ethernet show same issue?
What FW version is loaded on the system?
What brand and model# host router is the RBR connected too?
Make sure the RBR is connected to the host router using the RBRs WAN port to a open LAN port on the host router.
How is the RBR configured for AP mode? Dynamic or Static IP address configuration?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What wireless device are you using?
