Raymond3764
Oct 07, 2026Tutor
change email
Hi all, I have searched through other discussions, but I think it is not clear to me, so I will ask this question here. When I want to change my new email adress in the Orbi app at account se...
Oct 07, 2026Guru - Experienced User
Raymond3764 wrote:When I want to change my new email adress in the Orbi app
Netgear uses single-sign-on, so you need to change your primary email at my.netgear.com.
After that, you should be able to just enter that email address in the Orbi app. If that doesn't seem to work, try uninstalling the app and then reinstalling it.
