MickeyKelly
Sep 06, 2022Aspirant
Change topology from star to daisy chain Orbi 753
All of my Google searches say to go to the Advanced tab, Wireless, Advanced and change the setting. This option doesn't exist there. Can someone point me in the right direction?
You used to be able to change it on the AC versions but the AX versions don't have the option. I
- MickeyKellyAspirant
Thank you.
Daisy Chain is automatic on Orbi AX systems. Based on placement to the RBR and RBS out in a line and how they are turned on will determine how they get connected in Daisy Chain layout.
Thank you.
