fat_dog23
Aug 13, 2020Aspirant
Combination of AP mode and satellites results in massive security issue
Hello, I have a problem with my NETGEAR Orbi RBK853 (1 router, 2satellites) in AP mode in combination with a Fritz!box. The Fritzbox takes care of the DECT telephone and the Internet, directly behind it is the ORBI router, to which in turn 2 satellites with Ethernet are connected. This works very well so far, but the satellites generate a 5 GHz WiFi network that is completely unsecured. This cannot be turned off on the satellites. The WiFi-network is WPA2 secured on the router. I have already installed the latest firmware V3.2.15.32_1.3.25, unfortunately without success.
The problem only exists on the satellites and only, when I am in AP mode, everything is ok in router mode.
Setup on Satellit:
Spoiler
- Hardware Version: RBS850
- Firmware Version: V3.2.15.32_1.3.25
Orbi Satellite WiFi Status (2.4GHz)
- Name (SSID): mywlan
- Channel: 13
- Region: Europe
- Wireless mode: Up to 573.5 Mbps
- Wireless AP: On
- Broadcast Name: On
- Security Type: WPA2-PSK[AES]
Orbi Satellite WiFi Status (5GHz)
- Channel: 36 + 40(P) + 44 + 48
- Region: Europe
- Wireless mode: Up to 2402 Mbps
- Wireless AP: On
- Security Type: None
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-SystemDo the RBS report same no security if wirelessly connected?
Can you configure the modems DMZ for the RBR and change the RBR to router mode and see if the RBS still report same problem?
